Old 29th March 2011, 09:39 PM
mreddaway32518 mreddaway32518 is offline
Default Upright Dimensions
I'm in the planning phase of my kit car fantasy. It'll probably be some time before this is turned in to a reality but you've gotta dream right?!
I was thinking of using an mx5 as a donor, including the front uprights. To plan the suspension I need the dimensions so that I can get the angles correct.
Does anyone have the distance between the top and bottom mounts on the uprights as well as the location of the steering arm ball joint on the upright?
Failing that I'll have to use my E46 as a donor (which could be interesting) seeing as I can't sell it (nudge nudge)...
Thanks for any information.
