Old 29th March 2011, 10:06 PM
Default 3 wire fire on a 1.8CVH
Ok. So this is to prove that wiring a sierra engine loom is not a difficult job.
I took my 1.8 CVH and dumped it in the car last week. made up the engine mounts over the last week. and then strung the loom round and connected up the multiplugs to the sensors .
Then connected the main power feed and earth on the loom to the battery. It's difficult to do wrong!!!
It's then 3 wires to a fire.
1) on a post 90 loom find the black wire on the 6 pin multi plug ( I will reference the <90 if you like ) and put 12V from the battery to it.
2) put 12V from the battery to the +ve side of the coil ( which shoudl have the -ve connected to the loom)
3) touch the starter solenoid wire with a +12v feed from the battery
http://www.youtube.com/watch?v=0wmQZOEwR-4
