Old 3rd April 2011, 06:29 PM
rincewind23 rincewind23 is offline
Default Front lower wishbone plate bending
Hi all,
Now my chassis is finished I'm starting on the wishbones. I am stuck at the point where I have cut the plates for the front lower wishbones, following the dimensions in the book. I am having trouble putting the 10 degree bend in at the bend line. I have tried clamping and bending it (obviously not going to work with 5mm plate!), heating and bending (still no luck). Thought about banging it with a *really* big hammer, but managed to convince myself that was unlikely to end well before I tried it (plus hitting exacly 10 degrees would be next to impossible..)
I just wondered how others have approached this problem - I thought about putting a groove in at the bend line with a grinder, bending, then putting a weld bead along the groove for strength. I'm not sure if the groove would weaken the bend and the weld bead wouldn't help - I'm hoping someone better at engineering than me might be able to help out.
I've got a 6-ton bottle jack if there's any way I could build a jig to bend the plate and use the bottle jack.
Cheers,
KEv.
Old 3rd April 2011, 09:15 PM
Try a couple of bits of heavy angle in conjunction with the jack to form a press and use the point of one angle in the vee of the other.
Old 4th April 2011, 05:46 AM
the proper tool is a press brake.
http://en.wikipedia.org/wiki/Press_brake
someone near you has one, it could be a sheet metal fabrication shop or heavy metal working shop. Take a copy of the book to show the guys what you are building and ask them nicely to bend it for you. Take a 24 pack of beer to reward them.
Originally Posted by rincewind23 View Post
Hi all,
Cheers,
KEv.
Old 4th April 2011, 11:58 AM
Where abouts are you? I used a press in the engineering shop next door. Just popped a bit of 5mm plate into the machine to test the angle before I risked putting the wishbone plates into it!
Old 4th April 2011, 12:17 PM
Cleckheaton - M62 Junction 26.
