Old 7th April 2011, 06:51 AM
Wgroove Wgroove is offline
Default Zetec Engine
Hi Guy's,
I'm planning to buy a ford zetec 2.0 engine from Kitspares.
Am i correct that after this i only need to buy an ECU to get it started ?
This is their description:
FORD 2.0 LITRE ZETEC ENGINE 136 bhp
The engine comes with the following ancilliares;
Fly Wheel and Clutch
Coil Pack and Leads
Exhaust manifold,Inlet manifold and Throttle Body
Injectors and Fuel Rail with regulator
Engine Wiring,Idle Control Valve
Water Pump
Thanks,
Wim
