Old 7th April 2011, 07:49 AM
Default Build Diary Thread/Ordering Steel??
Hi,
Last week I found a thread either on here or on the locost forum that listed a number of build diaries, one of them had an excel sheet which calculated the amount of steel needed to be ordered to build a haynes roadster. Can anyone link me this thread as I can't find it now or help with amounts of steel needed to be ordered?
Many Thanks
Chris
Old 7th April 2011, 07:59 AM
Adrians list is very good,
I tend to order 6 lengths of the 25mm tube & 3 lengths of 19mm tube per chassis kit, tho this does leave me with a little spare as the tubes are supplied in 7.5mtr lengths so it depends on the length supplied ( if that makes sense )
A little spare left over steel comes in handy for making dummy shocks etc .
Old 7th April 2011, 08:09 AM
Adrian, it was your build I was looking at thanks for quick response really handy info there! So I will be getting 6 meter lengths so will need 7 x 6 meter lengths of 25 SHS 2mm thick Walls and 3 x 6 meter lengths of 20mm SHS 2mm thick walls. The book says 19mm and 16swg but 16swg is only 1.5mm thick and the coompany supplying says 19mm is called 20mm, I assume this is the metric euro size. Will this be ok? Oh and it does have to be seamless, correct? Thanks Andy for your info too!
Old 7th April 2011, 06:29 PM
19mm is 3/4inch in old money.Doesnt really make a lot of difference 19mm/20mm just depends on supplier.42m of 25x25x2 will be enough for any cockups etc (sorry mistakes ).ERW,Seamless,SHS again all have a seam on the inside so wouldnt worry too much.ERW does have a squarer edge though.
CTWV50 put your location in your profile as it may help in future.
Old 9th April 2011, 08:01 PM
SHS/HRS is known as black and is a crap material to work with. It has very rounded edges which means blades tend to side along it till they bite and comes covered in black graphite type oil which gets every where. Spend alittle more on ERW 25x25x2mm or 1"x1"x14gauge I ordered some on wednesday it was £12 a length 6mtr nominal.
Old 9th April 2011, 09:33 PM
Tilly819 Tilly819 is offline
you can go down to 16swg if you want to save a little weight
tilly
www.heraldic-motorsport.co.uk
Old 9th April 2011, 10:52 PM
eSteve's Avatar
eSteve eSteve is offline
Default Would this be of any use?
Chris,
I created a spreadsheet (Excel) last year when I was working out how much steel to buy and what the cost would be.
The spreadsheet lists all the steel lengths from the book drawings and calculates what lengths of steel and of what type you need to order.
If you know the unit price and the unit length (for my supplier it was 6 m) it will calculate the cost and if you'd like to lengthen the cockpit a little (as I did) you can do that too and the quantites are updated.
In the end I over-ordered on the steel quantities given in the spreadsheet, since I wanted to fabricate a few other bits and pieces (e.g. a welding trolly), so you had better check it before you start placing orders and spending money. I also bought some 25 x 50 which (as the book says) can be subsituted with multiple lengths of 25 x 25.
If you think it maybe of use to you (and if anyone else would like a copy) pm me with your eMail and I'll send you a copy.
There is a snippet of it from a screen-shot:
Regards,
eSteve
Old 6th July 2012, 03:36 PM
pbdata pbdata is offline
Im glad to recive a copy of your excel sheet for steel. Thanks Kjell
