Old 7th April 2011, 08:43 PM
KAMBO KAMBO is offline
Default rear exiting exhaust ?
Has anyone attempted a rear exiting exhaust rather than out the side ? if anyone has please post up some piccy's as i'm curious
ps.........i will be running a bike engine
Old 7th April 2011, 09:08 PM
A few people have thought about having an under car exhaust the only problem is lack of space. If you run a 45-60mm OD hot tube through the tranny tunel you'll heat the panels,the fuel line will most likly run through there as well which the IVA inspector won't like , the wiring loom needs some where to go too. Then theres the problem of ground clearance and the fact that you'll need alot of bends which won't be cheap either. There is a reason that the exhaust comes round the out side of the car and that is because it's the simplest way to do it. If you like the tractor look you could put risers through the bonnet and a collector box on top!
shh120m's Avatar
shh120m shh120m is offline
im toying with the idea of doing that because then i can use my standard manifold and just add a 90 degree bend to the downpipe. I have an exige rear splitter that i wanted to graft onto a grp rear tub and run the tail pipe through it.The reasons currently persuading me not to are, ground clearance,
heat under the car and exaust passing directly under the fuel tank, the work involved in modifying therear tub frame and a rear tub and the fact that i want to get my car on the road within the next decade!
Having said that, its definatly possible, it just looks like a lot of hard work, for a minor cosmetic improvement.
Old 7th April 2011, 09:09 PM
shh120m's Avatar
sorry phil, didnt notice your reply, or we were replying at the same time!
Old 7th April 2011, 09:57 PM
False floor on the passenger side was the concensus of opinion last time this was discussed.
Old 8th April 2011, 01:05 AM
tex tex is offline
westfield do an option for rear exit exhausts - doenst look too nice tho in my opinion.. lots of reduced floor clearance issues as it wont actually fit in the tunnel but just near to the prop
Old 8th April 2011, 06:40 AM
John.W John.W is offline
Have a look here
www.rcb7.de
The cars are very much the same but I think the ride height is a lot higher
Old 8th April 2011, 08:05 AM
loony's Avatar
loony loony is offline
Or maybe something like this - "front exit" ?
http://www.youtube.com/watch?v=yDxkeSDYR4w
Lucas
ZX9R BEC Haynes Roadster - build cost so far: £1125
My build thread
"Whatever you can do or dream you can, begin it. Boldness has genius, power, and magic in it." J.W.Goethe
Old 8th April 2011, 02:31 PM
thats more like it
