Old 8th April 2011, 10:03 PM
jimmy wonder jimmy wonder is offline
Default how much power....
how much power.....can the rear wishbones and uprights cope with when done to haynes spec?
i want to cossie turbo mine and i fear the arms/wishbones will be weakened with prolonged heavy action.
any info anyone?
Old 8th April 2011, 10:30 PM
Eternal Eternal is offline
Hummm im not sure to be honest. I know im going to be running around 250 bhp at the wheels im using the stock wishbone design. i would think the uprights would be ok and the wishbones as well. I belive the first place to go would be the brackets would bend/twist a bit. Thats probably the first place im going to add extra strength.
Edit: Then again the wishbones were not designed for that much power heh. So maby a revisit at a later date will be worth doing. Will run with stock wishbones for a few months on the road and see how it goes.
Skyline Roadster
Old 8th April 2011, 10:54 PM
The YBx power delivery should be well within the capabilities of the suspension.
The delivery of both power and torque does not come in until the vehicle is rolling so the strain on the components is reduced.
Old 8th April 2011, 11:15 PM
Persnonally, not based on any science at the minute. I would suggest using thicker walls for chassis and wishbones. I would suggest wishbones are least affected and it will be chassis, and engine/gearbox mounts that will take the hammering.
Old 9th April 2011, 08:29 AM
i have got a saab turbo in mine makes a bit more power than a standard cosi lump. everything is standard and its fine.
Old 9th April 2011, 12:36 PM
Wynand's Avatar
Wynand Wynand is offline
Im using a 3SGTE engine (turbo) that will be good for about 170-180kw (230 - 245hp).
To make sure the IRS at the back will handle that, I really supported everything in a big way - double upper and lower bracket carrier beams jointed together to prevent twist, some diagonals etc. The wishbones are 25dia x 2mm tubing.
At the end of the day the rear end may look like a Chines bamboo scaffold with all the tubes, but Im sure will get the power down on the tarmac, and the little extra weight at the back wont hurt either
Here are some pics.
Wynand
http://5psi.net
Old 27th April 2011, 08:03 PM
thanks guys,
my engineer(who has no kitcar building experience but does make wishbones for the van dieman race cars) said "it might be possible to use higher grade steel to make the wishbones therefore not altering the dimensions" and then strengthen the brackets too.
