Old 16th April 2011, 11:19 PM
trick-kit trick-kit is offline
Default CP Kits, opinions please
Hi fellow forum members,
I've been having a think about how to make things easier to do, i have had a look at the CP plates to begin with and this is what i have come up with. Other parts will be looked at to help help make things easier & reduce costs where ever possible.
The parts that make up the suspension towers, CP3, CP4 etc etc have been designed to key together to make life a bit easier. The shock brackets then slot in and when in place are 19mm away from the edge to correctly locate tube RS15. CP14 is cut to the correct length and I have put a small cut out in it to point out which way up it should go. Other little tweeks here and there have been done too.
So what do we all think?
Cost will be for a full set of plates (CP1 to CP25) including the shock brackets is a very reasonable £75 collected, or if you require it posted £79.99
If you are interested in one of these kits, drop me a PM,
ATB
TK
