Old 21st April 2011, 05:53 PM
brainbug007's Avatar
Default Putting polybushes onto the wishbones
I started trying to get my polybushes and made a dogs dinner of the 1st one. I can't get the poly bit to sit flush with the bone as I made the mistake of trying to put both bushes and the crush tube on at the same time... Now it's too wide to fit in the suspension bracket and I cant figure a way to get it back out to put it right. So my question is whether to try getting it out somehow or can I just widen the mouth of the bracket slightly to allow it to fit in?
Old 21st April 2011, 07:06 PM
can you file the Poly till it fits? A few strokes with a flat bastard should do it.
Old 24th April 2011, 10:26 AM
Filling them down a bit worked a treat, cheers minicountryman. Out of curiosity though does anyone know a good way to get them out as they'll eventually wear out and need replaced?
Old 24th April 2011, 11:34 AM
If they wear out then it does not matter if you destroy them in the process so you could drill or drift them out
Old 24th April 2011, 12:25 PM
Use the Force ! Brute Force !
Or the mechanics favourite BFI,brute force and ignorance.
Old 24th April 2011, 04:37 PM
They drift out easily enough.
