Old 29th April 2011, 08:44 PM
Default Rear Tub, HELP NEEDED!
I am sooooo annoyed with myself tonight. I was making the final cut to my body work and I messed it up. I should have measured 6mm but it was actually 11mm so I have a 5mm gap between the side panel and real tub. Below the wheel arch doesn't matter but what to do about the slither above?
I don't want to vinyl wrap the car to cover it up and at the moment I don't want to buy a new panel, I would rather put the £175 towards the IVA.
Any Ideas what I can do other than gluing a slither in for the moment and buying a new tub after IVA when funds allow?
Night then got worse as I cut my elbow and sliced my finger open on the tub. Also stabbed my dremel into my leg when I tripped over the cable
Pic of Fukup:
Old 29th April 2011, 10:28 PM
cornishmaid cornishmaid is offline
Use some "I" channel rubber to hide it.
Built February 2009 using Mx5 components.
Old 29th April 2011, 10:39 PM
les g les g is offline
Hi mate sorry to hear of your probs
but as cornish said some rubber might do i
try and google seals+direct they are great to deal with and have a fantastic stock
cant do a linky cuz i is puta illiterate
HTH cheers les g
Old 29th April 2011, 10:40 PM
David_17's Avatar
David_17 David_17 is offline
Me and Handy were discussing this gap the other day. It's the hardest part of the bodywork to get right. And rubber edge trim probably won't work as it's round a bend too.
I'm going to try a bead of silkaflex type stuff and see how it looks.
Andy was thinking of using an offcut of fiberglass as an overlap piece sorta thing.
*updated 7/6/11*
Old 29th April 2011, 11:16 PM
I got the other side Spot on it's just this side where I was looking at the wrong bit on my rule, I think rubber might look a bit wrong but it's worth a try.
At least your bodywork is White So you can hide it easily with White silicon/ sikaflex.
A fibreglass cover may look ok but might draw attention to it more.
Cheers for the replies guys.
Old 30th April 2011, 09:39 AM
Ashtonr Ashtonr is offline
Try fitting the rear arches then make a stone chip protector and fit to the rear arch and lap around to cover the join. I dont think you will have much of a gap to cover. I have trial fitted all the pannels and although I havn't yet made the cuts on the front edge of the rear tub and side pannels ( I just left then overlapping ) there wasnt much distance between the arches and this join. I can upload some photos if you need them
Rob
Old 30th April 2011, 10:56 AM
I think I'll have a look for some D trim that is flat, I only need a bit about 6mm wide.
It will cover the join on the other side and make it look even.
Old 30th April 2011, 11:09 AM
james3004's Avatar
does the wheel arch not cover most of it?
--- James ---
IVA passed 20 June 2017
Flickr Album
Old 30th April 2011, 01:08 PM
Most but not all, there is about inch and half showing.
Just below the handbrake ( handys) pic not mine
