Old 3rd May 2011, 09:26 PM
Default Flexy hose length
This has been asked before, so before I cut up some expensive hose what length are people using for the front hoses.
Cheers.
Old 3rd May 2011, 09:30 PM
ginger nutter ginger nutter is offline
think mine were about 500mm long for the fronts
Old 3rd May 2011, 09:37 PM
just on the back of this thread sorry if its a hi jack but where do you route it ? out the body then to the caliper i know but what about it rubbing on wishbones for iva ?
just popped into my head as i read it !
Old 3rd May 2011, 10:16 PM
Thanks Ginger,two schools of thought Rob,bolted to the side panel or run through it with trim around fitted to a bracket on the chassis.
Old 4th May 2011, 12:01 PM
axle's Avatar
axle axle is offline
Hi
It all depends where you are attaching it on the chassiss I got the location on mine according to the book.With steering on full lock it was 460mm.
Regards Axle
Old 4th May 2011, 12:21 PM
I bought 500mm long for the front & 450mm for the rear.
Old 4th May 2011, 04:09 PM
Thanks all for the input.
Old 4th May 2011, 04:35 PM
axle's Avatar
Thumbs up
No problem mate, I must say I do like your signature " It is not a kit car----"
rather cool yes it is a perfect sport car.
Regards Axle
Old 5th May 2011, 06:59 AM
Perxactically Axle(A mixture of perfect and exactly)
Old 5th May 2011, 07:59 AM
I thought the same thing until I fitted mine,
Mine are fitted as per book suggestion for the mounting bracket on the U1 & U2 & are routed thru the GRP side panel & thankfully they don,t go near the wishbone at all even when on full lock .
Mine are 450mm, but if I was to fit them again I would use 460mm length .
