Old 11th May 2011, 01:19 PM
MikeB MikeB is offline
Default Help with GRP Rear Framework
Thought I'd start a new thread on this.
I was hoping this would be a quick job as it looked really straight forward, after some cursing I can't work out quite how to fit this. If I had a rear tub it would be easy!
I got the GRP parts from Handy as part of his kit.
GRP2 as shown in the photo has a 5 deg end and a 90 deg end. From the pdf for the rear panel it looks like they should both be 90. So should they be straight cut if not which way round does this peice go?
The modified 19mm diaganol tube (that links the GRP rear to the diff carrier framework) doesn't seem to line up either.
Is the position of the flat plate that the tank sit on correct?
Has anyone got the height off the build table for the rear most 25mm tube , if i have this I can weld up and make the diaganol to suit.
IMAG0213 by mjb22001, on Flickr
IMAG0211 by mjb22001, on Flickr
Old 11th May 2011, 01:43 PM
MarkB MarkB is offline
From your pic i would say you have it upside down..
Old 11th May 2011, 01:49 PM
the GRP tube or D13 (or both!) lol. think I'm upside down, which way is up I don't know anymore!
I tried the GRP2 in a few different positions that just where it was when I took the photo.
Looking at DS13 this could be upside down?
Old 11th May 2011, 01:55 PM
The rear fibreglass sits at the same angle as if you were doing it as per the book, accept I angled the panel inwards so it looked better. downside of that was the book fuel tank is wrong shape...doh!
Old 11th May 2011, 01:58 PM
Ummm right well you have all that boxyness to hold the bones on..yes? then from that there are two tubes running backwards and up at an angle(whatever it is I can't remember...10degrees?) well to fit the grp you end it there and don't need the round tube with bendy ends..
Plain as porridge?
Old 11th May 2011, 02:09 PM
Richard Dryden Richard Dryden is offline
Default Just done this on mine
D13 should be up the other way so that the 40 odd degree angle sits onto grp2, the connecting bars onto grp2 should be angled up by 5 degrees from the front face, will measure the height from the jig of grp2 and post tonight. hope this helps
Richard
Just keep going we will get there in the end.
Old 11th May 2011, 02:28 PM
Hi Mike.....here are a couple of piccies of my grp frame and I did it as per the same pdf drawing I cut a notch to get mine right
Old 11th May 2011, 03:51 PM
Mike,
GRP2 should be square cut both ends as per my original PDF that you are using. I did however in the end notch the end of the diagonal tube as per Kev's photos above.
The plates for the fuel tank want to sit inside of the diagonal tubes.
Hope that helps
Old 11th May 2011, 06:32 PM
Thanks guys,
There seems to be two answers for the GRP2 tubes, one says angled one say straight.
Straight seems right to me.
Any other thoughts no this?
Old 11th May 2011, 06:47 PM
Easy way use a rear panel to line it all up...
