Old 17th May 2011, 06:44 PM
Peter-C Peter-C is offline
Default Quick loom question
Hi,
Can you tyrap the rear loom to the DS1 diff bracket ? I don't want to drill the bracket to fit a P-clip. Before and after ds1 it will be connected with P-clips.
Peter
Old 17th May 2011, 07:13 PM
Why do you need to attach it to the diff bracket?
Old 17th May 2011, 07:20 PM
Like an eejut, I took the fuel lines across the top of the tunnel and the brake and wiring along the bottom. Can't remember why, but it seemed a good idea at the time !!
