Old 17th May 2011, 06:14 PM
Andy_B Andy_B is offline
Default Its Rolling on bad wheels !!
Got my chassis rolling today need to do some work on engine would like it a bit more level sideways its perfect back and forward...got a petrol pump sorted so not far away from seeing if she will start !! Still trying to sort out seats....anybody !!
Old 17th May 2011, 07:25 PM
shh120m's Avatar
shh120m shh120m is offline
Wink
Looking great mate, I wouldn't say those wheels are that bad, at least they'd get you through iva, mine are all different sizes!
Old 17th May 2011, 07:42 PM
rapidtornado's Avatar
Have you still got the rollbar cross section to weld in? If not how are you mounting the seatbelt/harness anchors?
Rapid
Old 17th May 2011, 07:48 PM
Rapid
Yeah still have it in garage but no seats yet so i am holding off till i get them..also have 8 holes drilled in the welding bench in work ..which just happen to fit my roll bar mounting bolts..should keep distortion to a minimum when welding it in..
Old 17th May 2011, 08:25 PM
KAMBO KAMBO is offline
forget the wheels at least yours is rolling...
Old 17th May 2011, 09:57 PM
Cool..
I recon the granada wheels may just look fantastic when the body is on. They used a 4 stud version of that wheel on a wind tunnel test car for the original RS Cosworth, before they slapped on the cross-spoke style wheels.
Old 17th May 2011, 10:13 PM
JakeH's Avatar
JakeH JakeH is offline
looking good!
quite like the look of those roll bar stays, nice and chunky! what thickness plate have you used to mount them at the bottom?
Ta Very Much
JakeH
Old 17th May 2011, 10:29 PM
Cheers all...the roll bar stays bolt on to 4mm steel plate ...its good stuff my mate is a plater for a well known Govan builder of battle ships
Old 18th May 2011, 10:09 AM
Cool Another rolling chassis
Great to see another rolling chassis Andy
Looks as if you have made some great progress there
Old 18th May 2011, 10:13 AM
i think you should keep the wheels it would make my car look better when its finished and parked next to yours
well done!
