Old 17th May 2011, 08:07 PM
rich's Avatar
rich rich is offline
Default idler pulley
hi
does anybody know what idler/tensioner pulley to use for a 2.0 zetec black top?
Been trying to search for a suitable tensioner/pulley to fix to the engine so that the water pump spins the correct way. no luck.
had a Audi turbo one lying around and made that fit for now but it only has a 4 groove pulley.
as you can see in the rubbish picture
Old 17th May 2011, 09:26 PM
rich's Avatar
The plenum was fabricated, it was made to fit 2.0l injectors, throttle body and fuel rail
I had trouble finding the right pump, that was the only pump i could get that fitted in the housing (4 fixing holes) it was a nightmare trying to explain what engine i had
I have seen aftermarket idler fitting kits on ebay but there should be something OE thats cheap.
I had a nice little parcel waiting for me today, felt like a young boy again.
Its my omex 600 management. Will be wiring it up the weekend hopefully it might be turn key time!! Ok i might have more important things to do like connect the steering column to the rack and finish the front brake pipes, but i want to hear the engine running!!
