Old 27th May 2011, 03:46 PM
brainbug007's Avatar
Default Brake Piston Seals
Does anyone know somewhere to get piston seals from for drum brakes? One of mine was totally rotten and fell apart when I took the pistons out to clean them up
Old 27th May 2011, 05:54 PM
DaddyA's Avatar
DaddyA DaddyA is offline
Wouldn't bother with the seals just get a new cylinders - cheap enough.
Might be worth looking into a different bore size while your at it depending on what size drums you have! Its all to do with the rears locking up before the front and causing you too spin (IVA Fail).
I'm assuming there that your not using some sort of pressure reducer for the rears.
Probably confused the hell out of you there but go for new cylinders
Daz...
Old 27th May 2011, 07:32 PM
Confused indeed daddya with me being a bit of a nub! Any idea where I can get new pistons?
Old 27th May 2011, 09:04 PM
Local motorfactors
eBay
Old 31st May 2011, 05:29 PM
whole new units cost a fiver from your local autofactors so just replace
its geting hard to buy seals for cheap items like wheel cyl now
