Old 30th May 2011, 02:46 PM
David_17's Avatar
David_17 David_17 is offline
Default Argggggghhh!!
Starting to panic now.. My IVA date is getting closer and closer, and the car's getting futher and futher behind!!
Within the last few days, my fuel pump has packed in, speedo cable has snapped and wheel arch bracket snapped!!!
I've rewelded the arch bracket, and repaired the smashed up arch (primered, just waiting for paint in the post).
I've contacted speedy cables for a replacement and ordered a new fuel pump off ebay...
I knew i shouldn't have posted my application off on friday the 13th
Hopefully can get it all sorted in time.
*updated 7/6/11*
Old 30th May 2011, 04:00 PM
shh120m's Avatar
shh120m shh120m is offline
youll get there mate, if you ever want a hand im not far down the road. Im starting to get frustrated too, every time i get my engine started, something bad happens, its been in and out at least a dozen times now.
Old 30th May 2011, 04:08 PM
David_17's Avatar
Cheers Nath, just hope i can get it all sorted before the big day!
Likewise, if you ever want a hand, just give me a shout
*updated 7/6/11*
Old 30th May 2011, 05:26 PM
Likewise from me too David, my workshop is literally 2mins from your container so give me a shout if you get stuck with anything
Keep at it, you will get there no bother, you dont have to sleep at night you know!
Looking forward to there being another roadster on Teesside
