Old 2nd June 2011, 09:14 PM
Default Nissan Micra Radiator
If anyone is wondering, the Mk2 Micra radiator does not fit under the nosecone...doh!
Any suggestions for a radiator that will?
Old 2nd June 2011, 09:24 PM
VW Polo .
Old 2nd June 2011, 09:51 PM
MarkB MarkB is offline
Originally Posted by ozzy1 View Post
VW Polo .
second the polo but make sure it aint a white one with a big hole in the middle.
Old 2nd June 2011, 09:55 PM
Could you not tilt the rad back on an angle to fit under the nosecone? I think this is what others have done?
Old 3rd June 2011, 01:33 PM
Yep, I tried that and still can't get it to fit.
The only way I could get it in there was sideways, but that might be a little awkward when I have to fill it with coolant
Old 3rd June 2011, 01:43 PM
This is the one i've got.Not a bad price.
http://cgi.ebay.co.uk/VOLKSWAGEN-POL...item3f09bdf2e8
Old 5th June 2011, 08:20 AM
Actually, my previous statement isn't entirely correct.
If I remove the fan assembly from the micra radiator it will just fit under the nosecone.
Old 5th June 2011, 10:10 AM
That's not a bad price for a brand new rad!
I think I might go the polo route, this micra radiator is going to be more trouble than it's worth...
Couple of questions about the polo rad:
* What's the M22x1.5 hole halfway down the side of it for?
* It doesn't have a radiator cap like the micra and my donor did. Is that built into the expansion bottle instead on the Polo? Does that mean I would need a Polo expansion bottle too?
* What's the diamter of the hose connections?
Old 5th June 2011, 12:33 PM
The hole is for the fan switch, you can either use it or buy a blanking plug for it.
You do need an expansion bottle for it, mine came from a mondeo, and I think is the same one that Westfield supply
The hose connections are 32mm top and bottom.
Adrian
My Build Pictures:
http://s1234.photobucket.com/albums/ff406/adrianreeve/
Old 5th June 2011, 09:37 PM
Perfect, just ordered the ebay one above.
Thanks!
