Old 8th June 2011, 02:41 PM
misty misty is offline
Default P clips
Hi All
just a quick question
must the P clips be put on with rivits or can you use self tappers?
Old 8th June 2011, 05:11 PM
No reason why self tappers and a blob of locktight would be fine, I'm using rivets but its personal preference.
Old 9th June 2011, 12:22 PM
Less work with rivets,my personal choice.
Old 9th June 2011, 04:50 PM
super chaps many thanks
Old 13th June 2011, 12:36 PM
MikeB MikeB is offline
Hi jack slightly.
I orderd some 4.8mm p clips, they seem a little loose not clamping the brake pipe nothing bad I just expected them to be a nice tight snug fit, is this normal or should I order some more a different size. THe brake pipe is the standard 3/16? copper stuff i had a spare roll in my garage.
Old 13th June 2011, 01:09 PM
The ones that I got (maplin) have 3/16 printed on them. My pipes were loose enough to slide backwards and forwards. Once you have a few bends/kinks in the pipe it won't move.
btw 3/16 is the correct size for the pipes and m10x1mm unions 25mm long.
Old 14th June 2011, 10:57 AM
snapper snapper is offline
I have used little bits of push bike inner tube to take up the gaps
