Old 3rd July 2011, 11:36 PM
Default Roll Bar seat mounts IVA
I'm wondering at what height I need to put the seat belts for IVA. I read that in a crash that they can't pull on the seat so would this height be OK?? They are TRS belts running through cobra seats.
Would I be better off taking the belts around the seats rather than running through the cut-outs?
Old 4th July 2011, 07:00 AM
snapper snapper is offline
There is a diagram and measurements in the IVA manual.
A piece of wood 153mm long by 43 mm high placed on the seat pushed to touch the backrest, measure from the top front edge of the block straight up 450mm the draw a line horizontal back to the seat belt mounts on the roll bar, the mounts should bet at this height or higher.
For IVA don't put the straps through the seat run them round it.
Old 4th July 2011, 09:02 AM
MarkB MarkB is offline
Originally Posted by AdrianH View Post
Would those seat pass with respect to head rests? Well worth a read of the IVA book.
Adrian
Don't think they will pass IVA, there needs to be a form of head restraint.
Old 4th July 2011, 06:14 PM
DAHHHAAA I knew it!! Can you get the IVA manual online?
edit: google is your friend..doh!
http://mcelroymotorsport.co.uk/Docum...may%202009.pdf
Sorry to go of topic, but what's all this about having to have a CAT1 Immobiliser??
Old 4th July 2011, 06:31 PM
ginger nutter ginger nutter is offline
https://online.businesslink.gov.uk/T...rsion_0511.pdf
Old 4th July 2011, 06:41 PM
Ahh Section 15 Seat Strength
"6. A system of head restraint must be fitted on every outboard front seat."
Old 4th July 2011, 10:28 PM
With regard to the headrest, my slightly shorter friend sat in the car tonight and his head was on the headrest on the seat.
I may just fabricate a pad that comes down from the roll bar to satisfy the IVA tester.
Old 4th July 2011, 10:45 PM
Sounds like a good idea to satisfy iva tester, if your friends head was on the seat the harnesses must have been around his ears!
Old 4th July 2011, 11:05 PM
If you have a fixed head restraint the seats also have to be non-adjustable
Old 9th July 2011, 10:39 AM
Default seats
Is there an off the shelf seat that ticks all the iva boxes that i would get my lardy bot to fit in?
