Old 7th July 2011, 06:33 PM
Deanno's Avatar
Deanno Deanno is offline
Default Welding the chassis.
I have tacked the main part of the frame together and before i move it up the table to enable me to do the rear end, what are you views on welding the chassis completeley while it is still jiged up then do the rear end? obviously stager the welds to minimise distortion.
Thank you in advance.
(under construction)
South Wales Kit Car Club
WWW.HELPFORHEROES.ORG.UK
XBox Gamer tag: D34NNO
Old 9th July 2011, 10:49 PM
Thank you for this post Deanno : I'm at the same stage as you are, and I was wondering exactly the same question. It would be great to know what people think about that.
Thanks for telling us !
Old 10th July 2011, 12:21 AM
Deanno's Avatar
i intebd to tack the tranny tunnel first then fully weld it up whilst it is jigged then do the rest.
Old 10th July 2011, 10:37 AM
MarkB MarkB is offline
Make up the rear frame section that carries the wishbones as a separate piece obviously making sure it's square etc then and you might need another pair of hands, clamp it to the rear of the chassis in the right place. Doing it this way you shouldn't have to disturb the main chassis on the table. Once the wishbone frame is tacked on it will let you do the rest although it's over hanging the table.
In an ideal world the table should be longer but if you do it as above it will save any grief moving the chassis and the possible risk of something moving that you never noticed.
Old 10th July 2011, 11:11 AM
Deanno's Avatar
thats sounds a good idea, somebody said to me that the book shouls have said an 10' x 4' table but i suppose it comes standard 8' x 4'?
Old 10th July 2011, 11:40 AM
Indeed it does, standard sheets are 8 x4 in old money and summat odd in new money
Old 13th July 2011, 06:06 PM
Hi !
I finally made an extension to my table. Of course, I did my best to make it flat and levelled with the main table.
Board : 600x1200x22mm (main board is 2500x1200x22mm)
Timbers : 70x45mm section, two long pieces of 1200mm ans two shorter pieces on the side 510mm each.
I don't know if it is a good idea, but I feel more comfortable this way than moving the chassis forward or let the rear part hang behind the chassis. I guess there are more than one right solution !
I'll let you know if it was a good idea when the rear suspension frame is finished
Cheers !
Pictures :
Old 13th July 2011, 06:18 PM
Deanno's Avatar
thats a good idea, my table should take it after all its an 8' x4' pallet with 6 4" posts for legs and an 1" thick chipboard top (some would say a bit over kill) but it was free
Old 13th July 2011, 07:35 PM
"for free" is always a good reason !
