Old 11th July 2011, 03:37 PM
brainbug007's Avatar
Default Servo
This might be a daft question from a total newbie, but I'm starting to fit my engine and connect everything up and I know I shouldn't be using a brake servo but what happens to the vacum connection from the servo onto the inlet manifold? Should it just be left as is or do I need to try and block up the hole on the manifold?
Old 11th July 2011, 04:00 PM
vmax1974's Avatar
vmax1974 vmax1974 is offline
I am not an expert in any way shape or form but I would say block it up cause you dont want it sucking up any debris into your engine could do some serious damage
Old 11th July 2011, 04:36 PM
Sounds sensible, any ideas on the best way to do it? Would rather avoid the welder if possible..
Old 11th July 2011, 06:23 PM
Block it off otherwise you will have un-metered air.
Old 12th July 2011, 09:06 AM
So I guess I just get the welder out then??
Old 12th July 2011, 01:18 PM
Plenty of other ways without having to weld.
Old 12th July 2011, 03:52 PM
Can you suggest any other ways to do it?
Old 12th July 2011, 04:28 PM
vmax1974's Avatar
My old race car all I did was tap some threads and put a big bolt in
Depends which engine and what the outlet currently is.
Old 12th July 2011, 05:12 PM
Cut the hose, find a bolt that fit's the hose, apply ptfe tape or thread lock to bolt thread, screw bolt into pipe, zip tie or jubilee clip it just to be sure.
