after making an arse of my tub tubes rp1 etc with a plumbers pipe bender, i then thought an electricians conduit bender would be more suitable,
then.... i thought is there any good reason why i just cant use 20mm electrical conduit for these tubes? |
Don't see why not but they are usually galvanised so make sure and remove it in the area you plan to weld. I believe it gives off nasty fumes.
J |
Not sure about using conduit, but I did use a 20mm conduit bender to bend my tubes.
It didn't make a perfect job of them, and flattened them slightly, but it's good enough considering the ali tub is going to cover them. |
Thanks for the input guys, i might retrieve the tubes and give them go in the conduit bender.
Cheers Will |
any input is good as i'm using 20mm conduit some contractors left for me when they did a job, i told them i was building a kit car and asked if they had any off cuts 10 mins later he had to order 2 more lengths and a pack of 6 lengths turned up and he said it yours if you want it. bonus
My Blog: deannoshaynesroadster.wordpress.com (under construction) Being overtaken is a sign of weakness. South Wales Kit Car Club www.southwaleskitcarclub.co.uk WWW.HELPFORHEROES.ORG.UK XBox Gamer tag: D34NNO |
I used a conduit bender but packed the dies out with some duct tape to make the tube a bit more of a snug fit, It didn't work out to badly
Dont suppose using conduit is a problem but dont use the galvo stuff as fumes when welding are toxic. Also galv <zinc> plays havoc when it comes into contact with ally.
When The Results Disagree With The Theory: Believe The Results And Invent A New Theory If I had two brains I,d still be a halfwit The cave http://s1116.photobucket.com/user/my...deshow/mancave The build http://www.haynes.co.uk/forums/showthread.php?t=12669 |
You could of course just go buy a length of 7/8' 16-14gauge ERW clean mild steel then you'll have no trouble welding or bonding to it.
Website http://www.talonmotorfabrication.co.uk/ Direct email phil@talonmotorfabrication.co.uk talonmotorfabrication@gmail.com Mobile office hours 07514098334 |
true, but the conduit is free!
Im not a glaswegian for no reason ![]() |
I'm using 20mm conduit (Again for free) and have just done my bends today, what I did was cut 4 pieces about 1m long then where it says in the book the measurement BEFORE the bend add a bit extra.
I now have 4 90 degree bends which I intend to join by means of an insert into the pipe and weld fully ensuring I grind the galv off and use a mask when welding. alternatively buy the ones on ebay ![]()
| Thread Tools | |
| Display Modes | |
