Old 31st July 2011, 08:04 AM
brainbug007's Avatar
Default Pulley
Where should the missing tooth on crank pulley sit when engine is at tdc?
Old 31st July 2011, 10:55 AM
90 deg off tdc,dont quote me........
Old 31st July 2011, 11:17 AM
Where the pickup is.
Old 31st July 2011, 12:55 PM
When you say pickup do you mean sitting under the crank sensor?
Old 31st July 2011, 03:01 PM
std is tooth 9 at the pickup normal 4cyl ecus and anything with edis (9th tooth after gap with normal crank direction of rotation)
megasquirt2 with direct vr pickup can run it anywhere
see here http://www.msextra.com/doc/ms2extra/MS2-Extra_EDIS.htm
Old 1st August 2011, 09:01 AM
Nice one baz, thats exactly what I needed
Old 1st August 2011, 09:10 PM
see im not just a pritty face
