Old 5th August 2011, 06:59 PM
Default Exhaust build.
Well, Hopefully next week , I will be starting my exhaust build. The car is a little loud without it despite only being a 1.8CVH.
I have a Can from a Westie, and have orderd pipe up from Jetex in order to build up the system.
Old 5th August 2011, 08:55 PM
brainbug007's Avatar
Let me know how you get on and pics of how you do it as I'm getting close to this stage too
Old 6th August 2011, 07:55 AM
Yeah, have the RST manifold on. Should have it fabbed up fairly quickly hopefuly.
Did you do anything in the end to mate the RST head to the Sierra Head? I also notice the sierra gasket would leak badly if used is there an RST gasket?
Old 29th April 2012, 12:17 PM
Where can you get these SVC type exhaust silencers from as they don't appear to them anymore. Also what size is yours Adrian, as I remember it was very quite.
Old 1st May 2012, 12:43 AM
Thanks Adrian.
Old 7th July 2012, 10:13 AM
Adrian where did you get your pipe bent to spec? Cheers.
Old 7th July 2012, 09:59 PM
Originally Posted by AdrianH View Post
I did not, it is bends and bits cut and shut then welded and polished best I can.
Adrian
Ahh I see, good job! What gas did you use? I'm not setup for stainless, is it cost effective for such a small exhaust section? I do know a fabricator quite well maybe I could tack it together and take it to them for full stainless welding Hmm.
Old 8th July 2012, 07:15 PM
loony's Avatar
loony loony is offline
That's how I did exhaust in my last project - tacked with with stainless stick welder and then TIG welded by "professional"... it was much cheaper than custom made exhaust...
Lucas
ZX9R BEC Haynes Roadster - build cost so far: £1125
My build thread
"Whatever you can do or dream you can, begin it. Boldness has genius, power, and magic in it." J.W.Goethe
Old 8th July 2012, 07:50 PM
I am really lucky because my mate is a fine fabs welder for F1 teams and knocks out goodies like this for free. Mind hes had enough of my time
Old 8th July 2012, 10:07 PM
Thanks for the advise I think i have formulated a cunning plan!
