Old 21st August 2011, 09:51 AM
Cool Brake balance
I increased the front brakes to the 4x4 cosworth 60mm single piston calipers with 290mm?? i think discs front a cosworth 2WD, this increase in front brake efficency is enough to offset the rear.
Ive no reducers or proportioning valves in my system at all.[/quote]
Taken from another post, simple when someone has used a bit of lateral thinking. Nothing complicated just up the fronts to compensate.
