Old 24th August 2011, 07:06 AM
brainbug007's Avatar
Default Fuel Sender
I've got a few questions around the fuel sender if anyone can help:
Is it possible / worth using the donor fuel sender with a book spec tank?
My donor sender was a fuel injection engine so I believe the fuel pump is built into sender? Can these be easily separated as I'll be using a bike fuel pump?
If the above isn't worth it, can anyone suggest a cheap / compactish sender that would either work with the sierra instrument cluster or would work with a cheap iva compliant fuel gauge?
