Are these cheap clips good enough for securing things like electrics, fuel, & brake lines from an iva standpoint?
http://www.screwfix.com/p/snaplid-cl...k-of-100/75018 |
For brake pipes & copper fuel lines I used 8mm nylon 'P' clips riveted to the chassis.
http://www.ebay.co.uk/itm/20-x-8mm-5...em51861 85364 All the cabling is in conduit which is cable tied through rivet on bases. http://www.ebay.co.uk/itm/50-X-CABLE...item415c035bbc
http://s831.photobucket.com/user/dav...ter%20Pictures OTR 01/05/14 - 1.6 CVH, Type 9, Bike Carbs, Megajolt |
I have always used this type of split conduit and clips for wiring in the engine bay . They are really neat and as you remember stuff and add things just open the clip slide in another wire and pop it back in,
http://www.thetoolboxshop.com/0-326-...nw75-965-p.asp When you need a cable to exit the conduit just put a small hole in it on the other side of the split. when 100% done just tape in shut every 300 mm . Bob
When The Results Disagree With The Theory: Believe The Results And Invent A New Theory If I had two brains I,d still be a halfwit The cave http://s1116.photobucket.com/user/my...deshow/mancave The build http://www.haynes.co.uk/forums/showthread.php?t=12669 |
| Thread Tools | |
| Display Modes | |
