Old 28th August 2011, 08:52 PM
mgglep's Avatar
mgglep mgglep is offline
Default which wheels fit
Sorry if this question has been answered but came to put the standard 14" Sierra alloys on today and yes they don't fit after alot of swearing etc found out that I need a set of 15s my question is will a set of fwd Ford alloys fit for example mondeo etc or will the offset be incorrect thanks for the help in advance
Old 28th August 2011, 09:02 PM
Hi
As far as I know any 15" Ford fitment alloy wheel should be fine
Mk5/6 Escort, Mondeo & the likes
If memory serves me right the PCD is 4 X 108 & ET of 38
Here's a little info from Alloywheels.com
Make : Ford Model : Sierra Year : 84 to 94 PCD : 4x108 Offset : 35 to 45 Bore : 63.4
Most 4 stud Ford rims seem to fall within that range
Have a browse here
Alloywheels.com
Old 28th August 2011, 09:16 PM
mgglep's Avatar
Thanks for the info
Old 29th August 2011, 05:54 PM
peogeot have same pcd iirc
Old 29th August 2011, 06:07 PM
My wheels came from a Ford Puma (also a FWD Ford), the only issue with them is I can,t fit the center caps on the rear wheels ( which are very concave) due to the hub nut on the Sierra drive shafts . Looks ok without the center caps tho .
Old 29th August 2011, 06:12 PM
And some citroen........
Old 29th August 2011, 07:49 PM
mgglep's Avatar
Just seems silly that for the sake of slightly narrrower rear arms the standard 14s wouldn't fit afterall it is what the donor has on it
Old 29th August 2011, 08:48 PM
14" steels fit so some doners wil fit
Old 1st September 2011, 10:21 AM
Talking
There are a few things along the way like this but nothing that the lads on here have not got a answer too, just post your problems and an answer is probably just around the corner.I think there is more choice in the wheel and tyre options on the larger diameter wheels. And they are as cheap as chips.
Old 1st September 2011, 01:03 PM
mgglep's Avatar
Default peugeot wheels
I have been given a brand new set of peugeot 15'' alloys and tyres the hole centres are the same and the centre bore hole seems to be the same to you think the offset will be an issue
