Old 30th August 2011, 11:42 PM
misty misty is offline
Default mechanical brake switch
Hi All
bit of advice needed,
got a mechanical brake switch but dont know where to fit it on the pedal ,any ideas would be great
Old 31st August 2011, 08:54 AM
Wynand's Avatar
Wynand Wynand is offline
It depend if you have hang down or floor mounted pedals. And each method have different options based of space, design etc.
That said, I built my own floor mounted pedalbox and here is how I fitted mine - when the pedal was cut, a notch / cam was left for the switch activation.
I had to keep the switch in line with pedal for the bias bar push rods (not fitted in pics) to clear
Here are some pics of that.
Wynand
http://5psi.net
