Old 5th September 2011, 08:28 PM
Default Which fuel tank?
Does anyone know of any any fuel tanks from scrap donors that might fit my book spec chassis without too much modding?
The ones mentioned in the book dont seem to exist any more
Thanks in advance
http://s1189.photobucket.com/albums/...urrent=001.jpg
Old 5th September 2011, 10:04 PM
there are all sorts of tanks that could be used form other 7 kits if you use the grp frame to suppot your tank and ditch the diagnals at the back (d13 iirc)
a guy does new well made alloy 35L ish tanks new for £60 for robin hoods that fit in the hole without diagnals and will give you a full boot space if you need it
the orignal car has a real small tank and a grp bak end makes it smaller in my opinon it would be better to use the roll bar back stays to support the back tub buy bringing them all the way down to the grp frame to help take the load
thats what im doing
i had made a mock up of my own design then i seen the ones on ebay for £60 in almost the right size so got one to see im thinking i might stick with it now
Old 5th September 2011, 10:57 PM
Ashtonr Ashtonr is offline
Try http://www.alloyracingfabrications.c...fuel-tank.html I bought the 5Gal budget tank off them they changed it to include a swirlpot, baffles, sender hole, brakets and an allloy filler for I think £140 its excellent quality and fits in to the GRP rear frame perfectly. I spend about a week getting quotes of various companies and these guys were the cheapest by miles, took a week from order to del
Old 8th September 2011, 11:32 PM
they are good they made the ally tank i had in my vtec mini very nice bit of kit reasonable pricing and very helpfull im sortof thinking to use them again got a new challenge for them
Old 8th September 2011, 11:51 PM
Red face Too late thanks
Talon is doing a group build of steel long range custom tanks which will solve my problem and also mean a dont have to go to any of those nasty,dirty scrapyard places with big nasty oily dogs
Actually I love hunting through scrapyards but Id need to go into training now to build up the stamina
http://s1189.photobucket.com/albums/z429/ayjay50/
Old 9th September 2011, 07:15 PM
pradaloup pradaloup is offline
Renault 18 sedan
diesel or gasoline
you just changed the two bottom bar
