hi guys,
Will this pass??? Today i decided to sort the dash out. I have mounted warning lights, hazard switch and instruments behind the steering wheel. according to the manual all items mounted within a certain distance from the steering wheel 127mm are all exempt from the contact sphere test. According to that i think there is no need to pad the dash with foam and vinyl?? I have also rolled the bottom edge of the dash round a broom handle to the right radius. ![]() ![]() |
I think that one may have caught me out ![]()
I am not a complete idiot...........Some of the parts are missing !! Ronnie ![]() www.roadster-builders.co.uk |
I think I read somewhere that if no windscreen is fitted then the exemption zone behind the steering wheel does not apply. Therefore they can test everything with the radius sphere.
Might be worth double checkng the iva manual.
http://s831.photobucket.com/user/dav...ter%20Pictures OTR 01/05/14 - 1.6 CVH, Type 9, Bike Carbs, Megajolt |
not modded the dash, first time out the box today, just set the rpm signal. when you switch ign on it all lights up then displays 0mph |
Im not expecting it to pass first time, im sure the iva examiner hates every kit car, making him learn all 303 pages of iva rules and regulations lol |
lots of small jobs left to do like trimming and some odd p clipping here and there but almost there. Want to try and get the paperwork sent off this month and hopefully should get a test date for October. Next week should have the exhaust finished and fitted then its a session on the rollers to get the omex mapped |
to get my koso dash to pass i had to pull the buttons out so the speedo display was always shown they pull out easily with a bit of a tug as they are only held in with contact adhesive. i then used those little screw covers that hide the screws on kitchen units to cover the holes, held on with a little bit of contact adhesive. once i passed i just put the rubber buttons back.
My Roadster Is Finished NerNer....... Pigs can fly, you just have to carry them onto the plane. My Pictures http://s707.photobucket.com/user/ashgardiner/profile/ |
At our VOSA center, Beverley, it's acceptable to cover the buttons so that they cant be accessed to change fro mph to kph. But as we all know it's different for every inspector. I've heard of them just asking the question in the past and if you just reply with "no you cant change it to kph" that is okay.
AndyH
Haynes Roadster / Saturn GRP Bodywork. Now available direct through http://www.gillhamonline.co.uk/ or contact me direct on andrew.hugill@ntlworld.com Regards..........AndyH |
| Thread Tools | |
| Display Modes | |
