Old 13th September 2011, 03:24 PM
Peter-C Peter-C is offline
Default Which size tyres for IVA
I'm a bit confused over what size tyre to fit. I'm using the sierra gearbox and speedo and I want to make sure that the speedo readings are within IVA spec.
The sierra original tyres were 185/65 R14 and I am looking at Toyo T1R's. The perfect match are 195/55 R15's at Approx £60 each whereas 195/50 15's are £36 each.
Will the cheaper ones be ok. I assume that the speedo will read less than actual.
Peter
Old 13th September 2011, 03:40 PM
Gus's car went through IVA with 195/50/15 tyres, so go for the cheaper ones.
Old 13th September 2011, 03:51 PM
Cheers,
Thats was what I wanted to hear.
Peter
Old 13th September 2011, 04:11 PM
Hi Peter
As far as I know, 50 is the correct aspect ratio for a 15" Sierra wheel rim
This will ensure that the circumference of the wheel is correct for the Sierra's speedometer
I have a set of Toyo TR1's for my own build & they are 195/50/15
Old 13th September 2011, 04:55 PM
Cheers Ronnie,
I used this website for comparison.
http://www.etyres.co.uk/tyre-size-calculator.htm
I was sure that a lot of people were using the 50 profile ok.
Peter
Old 13th September 2011, 05:57 PM
Hi Peter
I use this site for reference.
Alloywheels.com
That said, I notice in the Haynes manual that both 195/65/14 & 195/60/14 were fitted to various Sierra models as standard.
195/60/14 had a V rating
Hope I am not confusing the issue too much
Perhaps the tyres speed rating has a bearing on the aspect ratio of the tyre ?
Old 13th September 2011, 06:59 PM
forget t1r's fit r1r's they stick like poop to a blanket compared to the t1r's which i now consider to be rubbish after fitting r1r's. i would guestimate that i have about 40% more grip now with the r1r's
Old 13th September 2011, 07:00 PM
my car will be 2 years old in jan and i have already been through three sets of tyres. track days are fun
Old 13th September 2011, 07:56 PM
Question
Cheers lads,
Are R1R's track use only ?
Peter
Old 13th September 2011, 09:01 PM
Question
I,ve just done a tyre size comparison between
185 / 65 / 14 = total tyre diameter =596mm
195 / 50 / 15 = total tyre diameter =576mm
so does this mean the speedo will under read ?
