Old 16th September 2011, 09:06 AM
kitcarkid kitcarkid is offline
Default saturn flat pack
does the saturn sportscars flat pack haynes chassis kit include the rear top suspension mount/roll bar mount section?? part cp6 i think
also does it include the steering wheel/column support?
thanks
Old 16th September 2011, 10:10 AM
vmax1974's Avatar
vmax1974 vmax1974 is offline
This is a question for spud but I believe they do come with all the chassis plates
Hope this helps
If you need to know quick why not give spud a ring and have a chat with him he is a very helpful bloke
Old 16th September 2011, 10:27 AM
Do you mean the chassis kit to accept the Sierra or the MX5 donor?
Saturn has a very good package available for the MX5 chassis which includes the full flat pack chassis kit & all the "CP" plates & the "EM" plates for £295.
When you say the steering column support ....do you mean SW1 SW2 & SW3? if so, then yes they come supplied in the kit, along with a fully welded front frame which saves the need to make a jig to weld it together.
If you are looking to use the Sierra as your donor then the flat pack kit is available for this too, give Spud a call if you need to clarify what you need & I,m sure he,ll help .
Old 16th September 2011, 11:17 AM
thanks guys and its the sierra version but im gonna be using a new 2.0 zetec and gearbox
