Old 16th September 2011, 06:56 PM
Default grp tub dimentions or profile (triton,satern)
im needing a profile of the grp back end. mainly to make my back stays.
what i realy need to know is the distence from the back of the top tube on the seat back or somthing simular and the inside of the top grp lip and the radius of the corners.
Old 21st September 2011, 09:08 PM
someone must have the gap from the seat back top to tub top (inside)?
Old 22nd September 2011, 09:00 AM
Hi Baz,
Sorry just seen this, haven't been on the forum much recently.
From the seat back to the inside edge of the rear panel you have 380mm clearance to the inner flange then another 20mm to the curved inside of the tub. If you are needing the measurement for the backstays you will be going to the lower section so will be well away from the rear panel edge.
AndyH
