Old 20th September 2011, 02:59 PM
Default Any generous builders
We need a pair of spline adaptors to fit on the lobro drive shafts we have for the single seater if anybody has a spare set from their build that they do not need or not used. We have the drive shafts just need the spline ends PLEASE.
Thought there is bound to be some unused on here.....
Many Thanks in Advance..........AndyH
Old 20th September 2011, 04:48 PM
Do you mean the diff output flanges? (not that I have any spare.)
Old 20th September 2011, 05:01 PM
Jimmyd Jimmyd is offline
If it is I have a spare 7.5 diff which I could rob if needed?
J
Old 20th September 2011, 05:15 PM
Thanks TT and Jimmy, not sure if they are the same but it's the outer flange to spline, wheel side, that we need. we have the rest but for some reason they are missing. The car now has engine running, diff and chain fixed so just need these to get the rear wheels spinning.
Cheers....AndyH
Old 20th September 2011, 05:37 PM
Ahh right, the rear stub axle.. Still not got one spare mind.
Old 20th September 2011, 08:36 PM
Cheers....AndyH
Sorry don't have! Could have help'd if diff side.
J
Old 21st September 2011, 09:23 AM
Thanks again Jimmy and TT, just thought i would try the forum first.
Nathan has offered to lend the pair off his car just till we get sorted.
Cheers....AndyH
Old 21st September 2011, 09:28 AM
Certain sure that I have a spare pair here
I'll have a root about later this morning & drag em out.
They are the standard Sierra ones from a 2l with rear disks fitted ( 7" Diff )
Is it just the flanges you need ?, I have the bearing carriers here but they are a tad crusty & possibly in need of new bearings.
Hope that helps
Old 21st September 2011, 10:43 AM
Hi Ronnie,
That is exactly what we need, just the flanges. Bearings and everything else is ready to fit, for some reason the flanges are missing.
Thanks......AndyH
Old 21st September 2011, 12:04 PM
I'll root them out & get them in the post to you ASAP
Think they are in my top shed, failing that, they'll be down my inspection pit.
If they are down the pit, Junior will get em out when he comes in from work
