I've got a Clutch and cover plate (new old stock) sitting in my garage. I'm struggling to work out what they are off. Finis codes are 6104426 and 6104430. Any ideas what engine these are off?
Do you have the Ford part numbers? BV. |
AndyH
Haynes Roadster / Saturn GRP Bodywork. Now available direct through http://www.gillhamonline.co.uk/ or contact me direct on andrew.hugill@ntlworld.com Regards..........AndyH |
I have an old luk clutch book and both of those numbers come across as out of one kit which has an luk number of 622 0175 06 1.7 / 2.0 ford consul 1972 to 81 must be the old v4.
When The Results Disagree With The Theory: Believe The Results And Invent A New Theory If I had two brains I,d still be a halfwit The cave http://s1116.photobucket.com/user/my...deshow/mancave The build http://www.haynes.co.uk/forums/showthread.php?t=12669 |
I've had some advice off Locost Builders and it seems the clutch and clutch cover are off a Pinto RS2000 MK 2 Escort. But being Ford, fit a huge variety of other engines (Some Capri's Etc)
Edit: Looking at the Consul, that also had a 2.0L Pinto engine fitted in its later life. Last edited by deezee : 22nd September 2011 at 11:24 AM. |
That makes sense as they all used the same four speed box in their day.
BV. |
OK, so I've taken the other numbers off the boxes, but I don't know what they are. Both boxes are marked up Ford Motorcraft.
Clutch plate box has this sticker on it ECD 134 82GB 7550 AA 6104426 Clutch cover box has this sticker on it 82GB 7563 AA 6104430 ECP 120 |
just flicked through the luk book and that plate and cover combo are used in 1.6 cortina up 71 on, rs2000 and capri 2.0 71 on , the kit number changes because of the thrust bearing.clutch plate should be 215mm dia with 26mmx23 spline.
| Thread Tools | |
| Display Modes | |
