Old 22nd September 2011, 11:57 AM
brainbug007's Avatar
Default Power Delay Relay M5
What does this do and do I need it?
Old 22nd September 2011, 12:24 PM
Provides powerup controled by the ECU ( no idea why ), provides a switched supply to the pump relay (Which I think we have covered off already).
Old 22nd September 2011, 12:34 PM
Well it looks like it's got a black wire going to a solder joint where loads of other blacks meet, another black going to the edis, a brown going to a common earth point, and a red that goes off and splits to then go onto the ecu and engine management relay. I think it's the engine management relay you're thinking of for the switched feed for the fuel pump.
