Old 25th September 2011, 01:30 PM
will_08 will_08 is offline
Default CP10 which way
Might be a stupid question, I may have overlooked it in the book. But I cant see what way the 2 CP10 brackets go. is the hole 31mm from the edge or the 25mm from the edge hole to the top?? also what size holes have you drilled, ive just put a pillot with view to drilling it latter.
Cheers Will
Old 25th September 2011, 03:19 PM
It does'nt realy matter which way they go in as long as they're in the same way round, bare in mind they will need 'triming' to fit as the book length is wrong. We just put the holes equal from the centre line then theres no chance of fully welding either of them the wrong way round. Been there, done ,used the angle grinder!
Old 25th September 2011, 05:43 PM
Thanks Talon,
Id already offered them up and noticed they wouldnt fit in, thought it was me
Thanks again Will
