Old 10th October 2011, 10:49 AM
whitstella whitstella is offline
Default log book (v5)
hi
i have got a logbook for 1.8 sierra and 2 chassis plate, i was just wondering if they were worth anything to somebody on here before i ring and scrap the car, as i am now not building my car.
cheers steve
Old 10th October 2011, 10:51 AM
brainbug007's Avatar
Don't they check the engine number against the engine number in the v5 at iva though?
Old 10th October 2011, 11:02 AM
They only check the engine number at IVA to make sure it corresponds to the engine number you have put on your application and to determine the age of the engine block for emissions criteria (which you have to prove - easily done for Ford Engines). If you want an age related plate with DVLA you will need to submit the V5 for the donor car to prove that the engine you have used originated from the donor car, otherwise you will get a "Q" plate or if you can prove that all components are new, except one major reconditioned part, a new registration.
I have sent you a PM Steve.
Hope that helps....>AndyH
Old 10th October 2011, 07:10 PM
not quiet true it is possible to use a diffrent engine from a diffrent car and still get an age related plate if you use enough doner parts from the orignal car. dvla look at what you have used give each part an amount of points and asses if it would qualify to have enough points to get an age related plate.
(im building a case for my car to have age related plate)
as you only have a logbook and chassis strictly speaking it is worthless to get an age related plate without the orignal parts to go with it.
odd thing is the engine block would be the only identifyable bit of a sierra unless it was clearly not a part that was fitted to the car on the logbook
Old 10th October 2011, 07:31 PM
It all depends on the person at dvla as always
David17 got a new reg even though his parts were all sourced seperately and second hand!
Drury who used to post on here got age related i think, even though he was using a zetec he had enough points to get age related
The girl who inspected mine said i had the minimum ammount needed for age related but i used the original sierra engine too
Old 11th October 2011, 10:28 AM
You're right Baz, it states 3 major components used for the donor to get an age related plate. The engine does tend to be one of them and as it is the only traceable component from the donor they like to see it.
BUT as Mark says there are so many anomalies it does depend a lot on the inspector and DVLA local office....
AndyH
Old 11th October 2011, 03:59 PM
Is there any advantage to having an age related plate as apposed to Q plates or new ones? I'm thinking maybe Inusrance?
Old 11th October 2011, 04:15 PM
Insurance can be an issue with some of the brokers,but not with the specialist brokers like adrian flux. The Q plate once on stays on and if you want to put a cherished number plate on at a later date you cant. The only other thing is a Q smacks of the home built kit car made up of loads of bits image. Wrong as this may be resale would be higher with an age related . Can of worms officially open
