Old 26th October 2011, 04:59 PM
gaz05 gaz05 is offline
Default Sierra calipers and discs
Looking around for calipers and discs because the ones on the donor were shot. I'll probably get new discs as they're normally quite cheap and I'm just going to use Sierra calipers for now rather than expensive aftermarket ones.
What I want to know is which calipers? Are the uprights the same for all models? Would I get more braking power if I went for ones with a larger bore .
Why can I buy vented disc calipers for the 1.6 when the book says they only had solid discs?
Total cost so far
Materials £3,150
Tools £855
Old 26th October 2011, 05:28 PM
260MM Vented is probably the most common configuration you will find these days.
260MM Calipers are bigger with Bigger bore, and there are two types of mounting bracket onr for RWD and one for 4x4.
Old 26th October 2011, 06:22 PM
Cheers Rob. The book says 240mm up to 2.0L. Theres some on the bay from a 1.6 with 54mm bore. Might put a bid on them.
Total cost so far
Materials £3,150
Tools £855
Old 26th October 2011, 06:31 PM
ABS cars generaly have 260's as did any V6 .
Later 2.0's seem to have 260's but it's not always true!
Old 26th October 2011, 07:32 PM
Try local factors,I paid about £26 for new.
Old 26th October 2011, 08:27 PM
Gaz....
If you get stuck I have a spare set of front calipers , they accept 240mm vented discs.
They came off my donor & are working ok, tho I,d suggest 2 new bleed nipples .
They are spare as I managed to source a brand new pair ....nice n shiney
Old 26th October 2011, 08:42 PM
Thanks for the offer Andy. Plenty of time for me to find some as the car isn't progressing much at the moment.
Total cost so far
Materials £3,150
Tools £855
Old 26th October 2011, 08:52 PM
shh120m's Avatar
shh120m shh120m is offline
andy, il take second dibs on those calipers if gaz doesnt take you up on your offer, im stuck for front calipers, those daft wilwoods catch the inside of my wheel rims. I might have something to swap/ or a bit of cash
Old 26th October 2011, 09:00 PM
No Probs Gaz, I mentioned about my spare calipers if sourcing some was holding up your build progress ,
Nath....(as above ) , no worries mate, their yours if they would solve your braking probs,
Old 26th October 2011, 09:21 PM
shh120m's Avatar
cheers andy, il sort you out with a few quid, you at saturn saturday?
(edit- only if gaz definately doesnt want them, dont want to hijack )
