Old 29th October 2011, 11:31 PM
kiwilotus kiwilotus is offline
Default Drag Link Ends
Can anyone tell me what model or year transit van im surposed to get the top ball joints from for the haynes roadster any info would b apreciated.also what type of material are the suspension bushes made from? i have bought polyurathane but have been told it to soft and difficult to machine.
Old 30th October 2011, 12:09 AM
Transit 190 mk3 drag links can be found on ebay
http://www.ebay.co.uk/itm/Top-Ball-J...item5ae224b89f
Polyurethane can be machined but you need to know how to shape the tool to cut it but then it's not a great finish,propbably easier in the long run just to buy the poly bushes.
Old 30th October 2011, 09:45 AM
odd i cross ref ed the part numbers in book and the only model i found as a match is a mk1 transit 65-78 (right hand thread end of drag link)
i think the only co. that makes them now is qh
Last edited by baz-r : 30th October 2011 at 10:07 AM. Reason: add year of mk1 transit
Old 30th October 2011, 09:49 AM
kiwilotus going by your name im thinking your in nz. add your location in your profile then it helps people know where you are in the world
Old 30th October 2011, 01:48 PM
TSM Locost's Avatar
It seems that not all drag links have the same length of thread, some not allowing enough thread inside the top arm when fitted with a lock nut ( there have been comments of approx 20mm inside the arm).
Be Lucky, Mike.
