Old 30th October 2011, 03:38 PM
steve8274 steve8274 is offline
Default wiring query
hi all
can someone confirm where the wire from pin 56 on sierra stalks goes.
this is the pin which has 2 wires in. 1 wire goes to pin 56 on other stalk, other wire is not connected to anything
says they are earth wires, so does the other wire just go to an earth.
thanks
steve
Old 30th October 2011, 08:28 PM
davylock davylock is offline
According to what I can make out, Pin 31 is the one that goes to earth. Pin 56 on LH stalk goes to Pin 56 on RH stalk, The two wires on my stalks are BRN/WH Pin 56B, which goes to the earthy side of the Dip Beam Relay coil and BRN/YL Pin 56A which goes to the earthy side of Headlamp Beam Relay coil. Hope this helps but I can't ensure this is correct as yet as I'm in the middle of my own wiring as well!, Dave.
Old 30th October 2011, 11:12 PM
what year ?
Old 31st October 2011, 11:24 AM
Steve,
If you are using the Sierra loom than the other wire you are refering to would have been connected to Dim/Dip Relay B.
If you are making your own loom, you could connect the foglight relay to this wire to make sure it only works when the headlights are on.
Or just cut it off.
Old 1st November 2011, 09:25 PM
what year ?
hi
its from a 1992 1.8 cvh
thanks
Originally Posted by davedew View Post
Steve,
Or just cut it off.
not using the sierra loom, kind of made my own.
like the idea of connecting it to fog relay.
didnt know i could do that
thanks for replies
steve
