Old 2nd November 2011, 07:13 AM
misty misty is offline
Default aluminium window channel
Hi All
Has anyone got an idea of how to bend the ali channel for the window to fit into, thought about heat but not sure ,any ideas would be great
Old 2nd November 2011, 07:59 AM
If you have a flick through the book you'll come across a simple former that can be used as a template for the glass and to bend the chanel. Don't be temped to make the radious too tight though and don't use heat as this will aneal the ali and it will stay soft after you've bent it.
Old 2nd November 2011, 08:44 AM
THANKS for the info as i was going to heat it will have a look at the book and make the former
many thanks almost made a bloomer on that one
