Old 7th November 2011, 10:38 PM
Default MX5 Brake master cylinder?
Hi all,
What size brake master cylinder should I use for MX5 build?
Thanks
Old 7th November 2011, 10:40 PM
Default Master Cylinder
Use the one which is on the MX5. This will be the correct size for the calipers etc.
Old 8th November 2011, 09:26 AM
Yes John the original brake and clutch cylinder is matched to the brakes and is an ideal one to use.
AndyH
Old 18th November 2011, 06:21 PM
Does the MX5 master cylinder need modifying to be used with the pedal box/ does anyone fabricate a pedal box which will take the MX5 master cylinder ?
Old 18th November 2011, 07:36 PM
The only mod is for the pushrod so you can use the clevis pin with the pedal. There are now details on the updated guide on the Saturn website.
Regards....AndyH
