Old 14th November 2011, 02:49 PM
rpjg1975 rpjg1975 is offline
Default Water temp / oil pressure senders
Can anyone confirm the location of the water temperature sender (i believe its the one in the thermostat housing) and the oil pressure switch (guessing in the side of the block. I need to replace both to work a couple of gauges and take it the oe ones won't work correctly...
Russ
Old 14th November 2011, 04:03 PM
Russ
What engine is it?
Adrian
My Build Pictures:
http://s1234.photobucket.com/albums/ff406/adrianreeve/
Old 14th November 2011, 04:15 PM
Sorry, silly sod I am! It's a 1.8 cvh. Would help me to get answers wouldn't it?
Russ
Old 14th November 2011, 07:04 PM
How do I know the value of the oe senders? Will it be marked somewhere or in the haynes manual somewhere? According to the info on the website the water temp sender is rated at 287-23 Ohms. Am I right in thinking that the oe oil pressure sender is just a low pressure switch rather than a full range sensor?
Old 14th November 2011, 07:50 PM
Sorry they are rated in ohms, the value used to be stamped on them but that was a few years ago, the value can be checked at a given temperature but that information would have to come from a decent manual. As for the oil light switch it is probably just that.
Old 14th November 2011, 07:58 PM
Ok, cheers bob. I will do a bit of digging around. Not the end of the world if I have to buy new ones, water one is about a tenner and the oil one is about twenty. Enough, but not too silly
Old 15th November 2011, 09:18 AM
brainbug007's Avatar
Na you can get a replacement water temp sender for alot less. I broke mine accidentally and got a replacement off fleabay for £2.20 delivered (I'm also using a 1.8 cvh)
http://www.ebay.co.uk/itm/2706552463... 4.m1439.l2649
Old 15th November 2011, 08:41 PM
Those prices are from the company who made the gauges. From the info I have read I believed the oe sender wouldn't give the correct signal to my gauge. Gauges are from greengauges.
