Old 23rd November 2011, 03:04 PM
brainbug007's Avatar
Default Bike Carb Throttle Cable?
Can anyone describe (with pictures ) how I connect a throttle cable from my bike carbs to the pedal box? Also will the throttle cable out of my donor work or is there something more specific I need?
Old 23rd November 2011, 05:51 PM
To connect the throttle of my bike carbs I used a bicycle gear change cable. It already had a moulded on nipple at one end, I bought a solderless nipple for the other.
I drill through a bolt which was screwed into the back of the pedal box to hold the cable outer.
I then had a friend make a fitting to attach it to the pedal. This is able to rotate in the pedal.
The carb end outer is then fixed in a cable adjuster, with the nipple fitted to the carbs. I used an extra spring to get a bit more positive action on the throttle closing as I found it a bit lazy.
HTH
Old 24th November 2011, 08:24 AM
That does help loads thanks dave Few questions though:
On your 3rd picture showing the cable attached to the carbs, are those all just bolts with the center's drilled out like in your 1st picture?
What size bolts did you use and drill the holes in them to?
Again in your last picture, I take the cable coming off the carb on the right side (without the spring) I take it this goes down to the pedal box? How did you route it? Does it just go straight down at a 180 degree?
Old 24th November 2011, 11:01 AM
Hopefully you can see the route in the below picture.
On the carbs the cable seats in a proper cable adjuster. All the others are ordinary bolts just drilled through. I think from memory they were 6mm bolts with a 3mm hole to suit the cable.
Old 24th November 2011, 11:10 AM
Ah cool that helps to see the route. Next question being where'd you get the spring from and what size/desc was it? Also any ideas if there's an off the shelf version of the thing that goes on the pedal that your mate made?
Old 24th November 2011, 12:54 PM
Did some digging (probly should have done that 1st really..) but I guess its a "compression" spring that i want, so one of these? 6mm od, 4.83 id, 19mm free, 4.7mm compressed?
http://www.ebay.co.uk/itm/Compressio...item23131f7937
Old 24th November 2011, 01:13 PM
The spring was just one I found at work, but you need to make sure they are long enough to allow for the amount the throttle moves. I would say 19mm free length is to short. Mine is probably double that.
Plus the bolt has to go inside the spring so you want at least a 6mm I/D spring
Old 24th November 2011, 01:26 PM
Ok I'll keep digging for a longer and slightly wider spring. for the cable do you think one of these would be adequate?
http://www.ebay.co.uk/itm/Fibrax-Inn...item2a15cc22a7
Old 24th November 2011, 01:32 PM
That's the sort of thing I used.
Old 24th November 2011, 01:36 PM
Cool, found a better spring off the same person. Much larger compression range and i'll just have to use a larger M8 bolt at the top.
http://www.ebay.co.uk/itm/Compressio...item230d8de5ac
