Old 5th December 2011, 05:58 PM
Default brake and fuel lines where and attached with what?
mainly to post iva cars realy but where did you route your brake and fuel lines and what did you attach them to and what with
im using some copper 8mm feed and return lines and was planing on useing rubber lined steel p clips and have to fit my brake pipe as well with plastic p clips as well bt just opend the bag to find thay are 6mm and too big
i have fitted a welded steel floor and dont fancy having rivits poping up through the floor so i was going to put them in my trans tunnel but looks a bit tricky to drill all them holes in there
Old 5th December 2011, 07:20 PM
carlknight1982's Avatar
i ran ali strip down the tranny tunnel, brakes and fuel one side, electrics the other.
Roadster No 2 build
Cost to Date : £93
