			 Has anyone changed the front oil seal on a Type 9 Gearbox? (Bellhousing side).
			I have removed the front clutch release bearing sleeve to reveal the circlip around the bearing, and renewed the clutch release sleeve seal within my new hydaulic clutch cylinder, but I am concern about withdrawing the main shaft in case it does not relocate or cause damage. Does this have another seal behind the bearing? My workshop manual is for a 4x4 box which is totally useless! Also thinking about sucking out the old oil and topping it up while its on the bench.
			http://www.flickr.com/photos/29404787@N03/ http://www.flickr.com/photos/41021922@N03/ http://www.flickr.com/photos/56936222@N04/ http://www.flickr.com/photos/79486076@N06/ Finished my roadster after 5 years! Number 27! Last edited by Spikehaus : 11th December 2011 at 05:18 PM.  |
			 I don't think there are any more oil seals behind the bearing Nick.
			Looking at the Haynes manual & the type 9 gearbox, it only shows 1 oil seal in the release bearing sleeve & 1 o ring for the casting mating face. As per picture ( Ignore the clutch fork pivot pin, that photo was one that I had handy ) ![]() Hope that helps ![]()
			I am not a complete idiot...........Some of the parts are missing !! Ronnie ![]() www.roadster-builders.co.uk Last edited by Bonzo : 11th December 2011 at 05:28 PM.  |
			 Just turn the box over on a drip tray to drain it.
	You only get a woosh with a dump valve Build Thread Man Cave Mantiques Cecil Street Auto Repairs Garage Carlisle Build Cost £4181.65 - Last - Wheel Cylinders  |
			 Thanks Twin, that confirms I should have it sorted then as I have renewed this seal within the new clutch kit.  I just purchased a cheap oil pump of ebay to fill the gearbox through its filler bung. Just need to turn up a clutch locator pin now.
	http://www.flickr.com/photos/29404787@N03/ http://www.flickr.com/photos/41021922@N03/ http://www.flickr.com/photos/56936222@N04/ http://www.flickr.com/photos/79486076@N06/ Finished my roadster after 5 years! Number 27!  |
| Thread Tools | |
| Display Modes | |
