Old 17th December 2011, 08:25 AM
bertie_bas205's Avatar
bertie_bas205 bertie_bas205 is offline
Default Box section end caps....
Does anyone know how many open ends there are on a chassis??
(Or how many caps are needed to block the open ends of the chassis)
Bertie.
Cost so far? £1031.32 and i dont have one yet......
Old 17th December 2011, 08:39 AM
I think from memory it is 8. Why not just weld a piece of plate on to cap the box. It is what Gus and I did.
Old 17th December 2011, 08:59 AM
12 i reckon
Old 17th December 2011, 09:40 AM
Don't go by the sketch up drawings in the book as they are not the same as the tech drawings,its 10 and they are as follows
Top tube of the front frame FF4 x2
Bottom tube of the front frame FF1 x2
Intersection of BR5+6+12 x2
Ends of SB2 x2
Ends of RS14 x2
Old 17th December 2011, 09:53 AM
As Phil says 10,
but
its 12 if you are fitting a GRP rear tub .....the ends of the extra spar ( that I call GRP1 ), tho I would suggest welding steel plates on the end of this spar ( as Gus & Dave have done ) as if fitting a plastic end cap it "May" make it a very tight fit for the inside radius where the GRP tub meets that spar ( the plastic end caps tend to sit a approx 5mm proud).
Old 17th December 2011, 12:00 PM
i was thinking of leaving mine open and useing cavity wax inside the tubes
Old 17th December 2011, 07:19 PM
Thanks for the replies.....
Bertie.
Old 17th December 2011, 11:15 PM
les g les g is offline
or cut a little square of wod and tap it in then tidy the end wirh bodyfiller
cheers les g
Old 17th December 2011, 11:49 PM
The 4 in the front frame and the 2 at the end of BR5+6 could be plugged using plastic caps. The ones in SB2 and RS14 could just be filled with a piece of 20x20 box turned side ways and held in with silicone.
http://www.discount-towing.co.uk/pro..._Cap_25_x_25mm
Old 18th December 2011, 03:12 PM
TSM Locost's Avatar
Default End plugs
I can supply 12 plugs that have sharper corners to suit the thin wall box for £4.50 posted if anybody interested, send PM.
https://picasaweb.google.com/lh/phot...t=d irectlink
Be Lucky, Mike.
